1984 Bronco
Bronco185
Tucson, AZ
Hey. I just got a 1984 Bronco. The entire inside is stripped, but came with just about everything to reinstall. I have no idea how to put it all back together. My small brain cannot create the puzzle. Does anybody have any diagrams or any guidance to help me out? \\
Thanks
Stephen
Krafty
Ontario Canada
a haynes manual usually has a pretty decent breakdown of how stuff goes together, How far stripped is " stripped" is it the carpet and seats and seatbelts, or is it dash, doorpanels, interior trim as well as carpet and such?
Bronco185
Tucson, AZ
I have looked at that one. Yes to the metal. Only thing is the wiring out. Everything but the wiring. I am mainly trying to figure out the dashboard with all the ducting, vents, gauges and the wiring to hook up to it all. Thanks
Post some pictures of the area you are working on. It will be a great help in getting you the right answers.
Bronco185
Tucson, AZ
Those were great thanks!
Do you have anything for the passenger side??? The eater core area and up?
Good to see you trying to keep it going and back together!
Krylon Fusion Application pics in an 84 Source: by jkorbes at jines.org/bronco
DASH:
80-86 are the same style, then changed in 87 thru 91
Source: by justshootme84
So,
Dash Removal pics in an 86 Source: by BajaBronco13 at SuperMotors.net See more pics by clicking on Next
Auto Meter Phantom Dash Mounted pics in an 84 Source: byour good friend here, justshootme84 (Randy Z, Casual Mudder) at SuperMotors.net
Some diagrams by Ford via Steve83:
80-86 Cab Trim Modified diagram from TSB 93-15-13
Camper Shell Trim
1 Roof Trim Rear Moulding 517C04
2 Quarter Window Garnish Lower Front Moulding 29004
3 Pushpin N807154-SW
4 Pushpin, Nylon (2 Req'd Each Side) N807372-S
5 Quarter Rear Window Garnish Rear Moulding 29010
6 Body Side Window Garnish Moulding Front Bracket 29126
7 Bolt and Washer N800486-S9
8 ***** and Washer (2 Req'd Each Side, 1 Req'd Center) N801157-S58
9 Roof Trim Rear Moulding Joint Cover 518B34
10 Body Side Window Garnish Moulding Front Bracket 29070
'78-91 use 17 self-drilling oval-head 1-1/4" phillips screws with captive countersunk washers to retain all the trim pieces. 6 on each long trim, 2 on each short trim, & 1 on the small center joint cover.
'92-96 use 5 screws as above for the short trim & cover, 6 color-matched pushpins on each long trim, & 2 plastic pushpins on each rear corner trim.
Camper Top Trim U Nut Part Numbers in an 85 (Scroll Down); "...lipped to inside side panels under side window; 'extruded u nuts' or 'fold over nuts'; thread is 6mm x 1.0; Geno makes the u nuts. The part number is 8-12575 (2 pak). Regular 6mm x 1.0 bolts will work fine..." Source: by Chris B (Blue, bronco boy) at telus.net
Camper Top Trim Info & pics in an 86 Source: by justshootme84 (Randy Z, Casual Mudder) at SuperMotors.net
Bedside Panel Parts Break-Out Diagram in 80-91 Source: by HawkRdr at SuperMotors.net
Cluster Parts & Gauge Similarities, Mounting, & Removal info & pics in 80-96; "...The PSOM, lens, blackout ring, terminal clips, shifter plates, bulbs & holders are interchangeable between cases. 87-96 gauges are only held in by their terminal clips, except the speedo. 80-91 speedos are held in by 2 screws; 92-97 PSOMs are held captive by the surrounding gauge faces. 80-86 use the same case for tach & non-tach, with a blank face for non-tach. 80-86 gauges are held in by stamped nuts on threaded studs. The fuel, oil, & temperature gauge bodies are identical & interchangeable by prying the needle off & removing the 2 screws holding the body to the face plate. To reinstall the needle, the gauge must be powered & have a known signal applied (usually the minimum) before stabbing the needle so it points to the proper reading. The screws are 5.5mm (7/32") hex with T15. Note that both cases have a molded socket for an anti-slosh module (low fuel light, which was never installed at the factory) and both film circuits have 4 traces for the socket..." Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
Dash and Gauge Restoration pics in an 84
Source: by Dan P (Midnight Thunder) at SuperMotors.net
& go thru Dans' other sections for more interior pics
Dan's Interior Resto Pics
HVAC:
Vacuum Line Harness Pic in 80-96; "...80-96 similar, except 87-early 88 w/factory air; The 80-86 vacuum tank is a plastic ball on the R wheelwell..." Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
Vacuum Motor Locations in Parts Break-Out Diagram in 80-86 Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
HVAC Component Location, Vacuum, Controls, Wiring, etc. Diagrams & Overview in an 86 (Electrical and Vacuum Troubleshooting Manual (EVTM) Partial, Bronco for 86; see Pages 129, 141, 142 & 143, etc.) Source: by Chris B (Blue, bronco boy) at telus.net
Control Panel Diagram in 80-86
Source: by Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/clubs/superford/vehicles/registry/media/72336
Control Panel Swap in an 83
Source: by Michael C (collinsperformance, The Money Monster) at SuperMotors.net
Duct pic, in an 86 by Steve83
"After lowering the column, removing the big Aluminum casting, unbolting the 2 large connectors under the brake booster & releasing them from the firewall, the 3 connectors in the R kick, & the green ground ****** there are four 7mm (T15) screws along the w/s, an 8mm (5/16") at the R end, and two 8mm screws at the brace bars above the tunnel, and the dash flops onto the floor. Then the vacuum lines, HVAC cables, & antenna cable can be released, allowing the dash to come out..."
Bronco185
Tucson, AZ
That was awesome! Thanks! A LOT! I will post some in the process. I am doing a carb rebuild on a Holley in the morning. I am trying to see what 4 speed OD trans that i can hook up to that 351W. For minimal off road but for driving and keep some low rpms what could I do??? Is the c6 that good?
C6 is a tough trany, but it is a 3 speed. If you want a 4 speed you can go to a manual 4 or 5 speed, or an AOD tranny for a 4 speed auto. The Aod has a cable kick down vs a rod style kick down on the C6. See this from miesk5's index http://www.ford-trucks.com/article/idx/0/063/article/Complete_Overdrive_Conversion_for_7879_Ford_Bronco.html
Bronco185
Tucson, AZ
Is there a AOD from an F150 or something that would work maybe give me more efficiency (parasitic power) and help the motor work more efficiently. I have been trying to look to see about one from 302's but i dunno power wise. Thanks much for your input.
eholt80
