351 W or 302
70 74 Bronco
I just bought a '70 model project bronco. There are two engines: the original 302 (with 84 mustang heads) and a 77 351 W. I want to build an engine with plenty of low end torque for the bronco but be able to achieve decent highway mileage at 70 mph. A nice low rumble from the pipes will be great too!! Which engine should I go with? How much horsepower and torque should I shoot for when building the engine?
".....be able to achieve decent highway mileage at 70 mph."
---Good luck with that---- :eek: /emoticons/[email protected] 2x" width="20" height="20" /> :D /emoticons/[email protected] 2x" width="20" height="20" />
The 302 will do what you want....It already has enough HP & torque. Being freshened up will be better yet.
4x4'n is done between 800 & 1500/2000 RPM
Money spent on high HP will be $$ not well spent....unless you're runn'n the blacktop 90% of the time.
Go with the 351 if you can handle 8-10 MPG. (maybe 11-13 with the 302)
Also., the trannie type comes into play here as well.... B)
Bronc76
Take what Bob said into consideration, as I rebuilt the original 302 and I am satisfied with it. If it is the original motor from '70, the HP and torque ratings are already pretty good.
walkercreekbronco
I love my 351W. Incredible amounts of low end torque without a lot of money. However--I'm not sure I'd recommend the swap. It's a lot more of a pain than most will let on to.
Bronc76
I've always wondered about that, thats why I stuck with the original.
Sandoval_broncosauria
