transmission slipping
87'4U2NV
i changed the filter and fluid in my 87 ford bronco just for maitnence. when i got it put back together and added fluid it is now slipping! the transmission had no problems before i changed the fluid. any help?
50joe
Trenton NJ
Is the filter seated ALL the way into the trans? Frequently, when you pull an auto trans filter out, the seal sticks in the trans. If it remains, or if the new trans filter is not FULLY pressed into the transmission, it will slip.
87'4U2NV
the problem was i used mercon v! i dropped the pan the next day and put in dex/merc instead problem solved dont use mercon v
