Air Conditioning
90windsor
channahon
i want to get my a/c to work. the compressor wouldnt come on so i gave it straight 12 volts from the battery and it kicked on.
the thing is, the wires on the drier have been hacked into, and i hacked into the compressor wires to get it to work, so my question is, does anyone know which wires on the drier and and compressor need positive or ground? is there any way i can just wire it all up to a single switch, charge it and it will work?
or should i just charge it and see if the compressor will come on on its own then?
in other words, is it worth the money to buy all the recharge stuff?
thanks
That switch in your pic is a pressure switch, if you do not have the correct pressure it will not allow the pump to turn on. Also if you do not have the correct pressure it could mean you have a leak
90windsor
90windsor
channahon
so i should just be able to put a charge in it and it should work? thats the reason the compressor isnt coming on?
Root710
