aod swap to c6
muddinlate86
va.beach
on my rig i lost my tranny yesterday.been at the jy and shops all day no luck for one i would put in my truck.i found a c6 rebuilt frome an 82 for real cheap could i just throw it in or what would be a complication?any help would be nice im getting it in the morning
Ogeechee 4x4
Georgia
how long is the C6 compared to your AOD? You may need to lengthen/shorten driveshafts.
92bronco_in_progress
Yeah its a 92 bronco
Waretown, New Jersey
so i guess you had a trans problem
muddinlate86
muddinlate86
va.beach
i got a bigger problem now i just got my new tires(36x16.5r15)**** cipecs and i pulled up two feet and blew up my rearend.the bolt that holds the spider asembly together sheard off and got lanched threw my diff cover.it split it like a peice a papper
gatorbronco
Gainesville, FL
It's been awhile since I swapped mine, but I needed to change:
1. Shorten rear driveshaft...took it to a driveshaft shop and they welded it up no problem
2. I used the transfer case that came with the C-6 - NP205 I believe, not sure if you can use your current case...I'm sure someone knows
3. Needed to get a kick-down rod from an older F-150 so that downshifting would be possible.
4. Of course you'll need the shifting linkage from the C6.
5. There's a vacuum line that runs down to the tranny...don't think there was one for the AOD.
That's all that comes to mind right now, there's probably some other guys on here that know a little more about it. As far as your rear-end, that SUCKS. Time for some bigger axles???
yeah.....been there.....not fun......35's are the limit for those stock axles
muddinlate86
muddinlate86
va.beach
ive herd that 36s are the max you can runbut theres a better chance of breaking the u joints mhen mudding or driving hard.i hope that after my rear end gets rebuilt the tranny will hold till i can get a new one
i just had mine rebuilt........all brand new parts.....it ran me like 900 cause i don't have the tools or the know how to tackle it......plus i need the truck......its my DD right now
muddinlate86
muddinlate86
va.beach
i have a great mech.hes doing it for 200 bucks in font of my house!i also have made him like 5000 bucks in a mounth be word of mouth so he hooks it up
jsomedaysoon
outer banks nc
just curious, is the c 6 better than the aod. why are you going from aod to the c6. i've got the aod in my 86 and the c6 in the 84. both trucks drive completely different but i dont know how much is due to the tranny's.
muddinlate86
muddinlate86
va.beach
the c6 is the toughest tranny made to date over all. the downfall is its so heavy and theres no od.i just need a tranny swap but want to do it cheap so thats why i asked hope this helps
muddinlate86
muddinlate86
va.beach
yeah but its hard to decide if i want to take a chance on a jy tranny cause its alot of work changing a tranny and i hate tranny fluid!!!!!!!!!!!!!!!!!!!!!!
muddinlate86
muddinlate86
va.beach
true but the both **** and my whole street smelss like gear **** cause my rearend exploded and shot gears threw the diff cover
kyleh01
