lack of performance parts 1986
86 5.0 XLT
i found headers on summit but other than that i cant seem to find any other performance parts for my bronco its a 1986 5.0 any help please.
GSUEagles
Ga
the '87-'96 parts may interchange, depending on what you're looking for
shift1313
VA
there should be an endless supply of performance parts for the 5.0. what parts are you looking for? are you keeping it efi?
yo;
I complied a short list of perf upgrades for your 86 5.0
Summit shorty headers, ceramic-coated,
-Custom Y-pipe 2 1/4" pipes into Flowmaster Y, exiting 3" with header flanges into 3" Catco cat,
with 3" flanges, necked down to 2 1/2" direct into Oversized Walker truck muffler
-2 1/2" Dynomax mandrel bent tailpipe,
Taurus 3.8 electric cooling fan (to reduce HP loss in stock fan) by Sixlitre
rebuilt 302 w/GT40P heads & GT40P header pics by Christopher H
302 EFI speed density to 408 mass air installation by Chris P
MSD-6A ignition installation by Dustin S
Taylor 8mm spark plug wires or Ford Racing Spark Plug Wire Sets $41.95 (ign coil wire will prob be very long, set-up for a Mustang); also get wire looms spacers
MSD Blaster TFI $49.70 or Accel 48,000 volt coil, $46.00 @ Summit
K&N Filtercharger Air Filters $49.95
Search Summit by Make, Model, Year, Engine; here is what comes up
After you select what you desire; do a Google Search by mfgr name & part number for better price w/s&h - such as; KNN-33-2012
Enjoy!
86 5.0 XLT
i am going to keep it EFI
i was looking for intakes(Cone style) or safari snorkel
throttle body
intake manifold
wow that is quite a list thank you.
i found i bunch of parts for 88 and on broncos but the 87-86 model years were not listed did
they do something different with the induction systems on the 88 and newer ones
ok,
K&N is most pop cone style but they seem to have forgotten that 86 5.0 Broncos went to FI... you can try this:
57-2542 Product Specifications
Product Style: 57 Series FIPK
Estimated Horsepower Gain: 9.33 HP @ 3696 RPM
Type: Gen II
Replacement Filter: RC-3690
CARB EO Number: D-269-28
CARB Exempt: Yes
Weight: 12.7 lb (5.8 kg)
or
57-2503 Product Specifications
Estimated Horsepower Gain: 5.33 HP @ 3654 RPM
Type: Gen I
Replacement Filter: RF-1012
CARB EO Number: D-269-17
CARB Exempt: Yes
Safari Snorkel #SS395HF installation in an 85 5.0 by Chris
Edelbrock makes;
SUPER VICTOR 8.2 EFI (Up to 9000 rpm)
Super Victor 8.2 EFI is based on the Super Victor 8.2 manifold #2928. Designed for high-rpm street performance or competition 289/302 based engines with Windsor-style racing cylinder heads such as our Victor heads #77219 or Victor Jr. heads #77169.
I don't know much about this man...others have done similar upgrades; they'll jump in soon.
Throttle Body;
Ford
1986-95 5.0L MUSTANGS
Street legal for late-model 5.0L Ford Mustangs. 65mm size is ideal for stock manifolds. 70mm is the optimum choice for the Performer 5.0/Performer RPM 5.0 EFI intake and Total Power Package (70mm gained 10 hp over stock throttle body). 75mm is intended for more radical engine combinations and requires port matching to fit most manifolds. 1986-93 Throttle Bodies must be used with matching EGR Plates. Gaskets are included. See Ford S/B Fuel Injection Manifolds for 5.0L intakes
BBK
All BBK 1986-1993 Mustang throttle bodies are designed to increase airflow and improve horsepower from between 7-12 HP depending on vehicle and application.
BBK are the world
86 5.0 XLT
i think so as well thanks for all of they help.
just one more question. i want to go with a 3inch exhaust since im going to keep it a single system not dual.
a buddy of mine told me to make in 2.5 inches instead of 3 which would you guys go with
it will be mostly a road going car but i want it to sound mean as **** also
92bronco_in_progress
Yeah its a 92 bronco
Waretown, New Jersey
ok,K&N is most pop cone style but they seem to have forgotten that 86 5.0 Broncos went to FI... you can try this:
Type: Gen II
CARB Exempt: Yes
or
Type: Gen I
CARB Exempt: Yes
Edelbrock makes;
Throttle Body;
Ford
BBK
BBK are the world
kyleh01
