yo,"...Parts used in the ZF Tranmission Swap. I will probaly be fabbing up the transmission mounts for sale that raises the transfer case about 1.5" Stay Tuned.
Part Part# Source Cost
ZF S5-42 Ford/Junkyard Used $600
Rebuild ZF: seals, bearings, synchros LP Gear $500
Flywheel E8TR-AA Ford/Junkyard/Call Franklin
New $406
Used $40
Franklin $185
Flywheel Bolts MRG 912 Heinz Bros $8.75
Tranny Bolts 2- 1" Shorter than stock Heinz Bros $2.00
Pilot Bearing AutoZone 7.99
Internal Clutch ***** YL5Z7A5008AA Ford $66.65
Hydralic Hose F3TZ-7A512-A Ford $42.95
***** Cylinder Ford $62.29
Internal Clutch ***** Bolts Interstate Bolt $1.00
Clutch Disc CEN218226 Heinz Bros / Centerforce II $72.25
Pressure Plate CENCFT360049 Heinz Bros / Centerforce II $150.66
PP Bolts 3/8/18-1" Heinz Bros $5.95
Pedals 92-96 F150/Bronco J&T Automotive Used $35.00
Floor Pan 92-96 F150/Bronco J&T Automotive Used $20.00
ZF Shifter/Boot 92-96 F250 w/351 J&T Automotive Used $35.00
Driveshafts: +63mm in the rear, -63mm in the front
Need to use a wire jumper to bypass the neutral safety switch.
Phone #'s:
J&T Automotive 1-800-274-8090
Heinz Bros 1-704-872-8081
These prices will probaly be cheaper than most can find because I am running this through Corley Body Works, my brother-in-law's shop. But it will give you a good ball park.
Everything works fine. The truck may work better with a manual computer, will try when I go to J&T. But it is great and I recommend it highly.
Later, Jeff..."
by Jeff, a good pal
& more ZF and swap info & pics LINKS in my broncolinks.com site under
http://www.broncolinks.com/index.php?index=55
