jumping bronco????
Billy Toppless
Stuart
while sitting in the parking lot of my work waiting for my boss i had my bronco at idle with the A/C at full blast
then i notice my RPM twitching weirdly n the engine flexuating (sorry for the spelling on that :D /emoticons/[email protected] 2x" width="20" height="20" /> )
then driving home the rmp was twitching still n the bronco had a small jump/**** to it plus loss of power a bit
any ideas?
i just put new plugs, wires,cap n a roter in it like 3 weeks ago n was running fine untill today
im thinking dead cylinder or missfire?
hopefully something stuiped n simple like my air cleaner is clogged lol
can some one help me so i can get back to my restoration plans lol
Billy Toppless
Billy Toppless
Stuart
I'm with JSM.. Pull codes.WHile it could be TPS, it could also be MAP sensor, or even as simple as a vacuum leak.
If you've never done it...
How to pull codes...
http://broncozone.com/forums/index.php?s=&...ost&p=74581
im not throwing an check lights n i dont have a code reader but ill look in2 to, i didnt think to hookin it up to the reader cuz i got no lights on lol
is the TPS bolt on or adjustable?
and can u tell me where the MAP Sensor is and where its located?
im not throwing an check lights n i dont have a code reader but ill look in2 to, i didnt think to hookin it up to the reader cuz i got no lights on lolis the TPS bolt on or adjustable?
Billy, You are better than that!
You don't need a code reader. All you need is a 4 inch piece of wire. Just read the instructions in the link.
IT (pulling codes) is really easy.
ok i read the link n im gunna give this a trywhat a great write man
geuss i was just being lazy :-" n skipped the readings
thanks for ur help man
I hope that it reads well for you.
IF you find any part confusing, please let me know, and I will try to improve on it.
Good luck.
joe
tsebalj
