I HAVE A 1989 BRONCO TOOK IT MUDDING. SANK THE FRONT PASSENGER SIDE PRETTY GOOD. ACCIDENTALLY SHUT THE KEY OFF IN THE MUD, NOW IT WONT START ANY IDEAS?
[/qu
A flat-bed with a really long cable has become my best friend!
Your starter is on the bottom of the engine and on the passenger side, could you have ripped off some wires?I HAVE A 1989 BRONCO TOOK IT MUDDING. SANK THE FRONT PASSENGER SIDE PRETTY GOOD. ACCIDENTALLY SHUT THE KEY OFF IN THE MUD, NOW IT WONT START ANY IDEAS?
ms_jetset,A flat-bed with a really long cable has become my best friend!
ALREADY GOT ONE OF THOSE. COMES IN HANDYI HAVE A 1989 BRONCO TOOK IT MUDDING. SANK THE FRONT PASSENGER SIDE PRETTY GOOD. ACCIDENTALLY SHUT THE KEY OFF IN THE MUD, NOW IT WONT START ANY IDEAS?
THE TRUCKS OUT OF THE MUD. I HEAR THE FUEL PUMP THE BATTERY SEEMS TO BE FULLY CHARGED. SOUNDS LIKE IT WANTS TO START IT JUST WONT TURN OVER.I HAVE A 1989 BRONCO TOOK IT MUDDING. SANK THE FRONT PASSENGER SIDE PRETTY GOOD. ACCIDENTALLY SHUT THE KEY OFF IN THE MUD, NOW IT WONT START ANY IDEAS?
THE DISTRIBUTOR CAP IS FINE, NO WATER INSIDEI HAVE A 1989 BRONCO TOOK IT MUDDING. SANK THE FRONT PASSENGER SIDE PRETTY GOOD. ACCIDENTALLY SHUT THE KEY OFF IN THE MUD, NOW IT WONT START ANY IDEAS?
I WILL CHECK FOR ANY DISCONNECTED WIRES WHEN I GET HOME.I HAVE A 1989 BRONCO TOOK IT MUDDING. SANK THE FRONT PASSENGER SIDE PRETTY GOOD. ACCIDENTALLY SHUT THE KEY OFF IN THE MUD, NOW IT WONT START ANY IDEAS?
So.. when you turn the key, you hear the fuel pump prime, you hear the starter engage and turn the engine over, but she doesn't start.THE TRUCKS OUT OF THE MUD. I HEAR THE FUEL PUMP THE BATTERY SEEMS TO BE FULLY CHARGED. SOUNDS LIKE IT WANTS TO START IT JUST WONT TURN OVER.
I CHECKED ALL THAT YOU MENTIONED BUT THE CODESI WILL CHECK FOR ANY DISCONNECTED WIRES WHEN I GET HOME.
IF YOU COULD LINK ME THAT WOULD BE GREATI CHECKED ALL THAT YOU MENTIONED BUT THE CODES
To pull codes, all you will need is a short 4 inch piece of wire and the ability to count to ten.IF YOU COULD LINK ME THAT WOULD BE GREAT
Wow! Good point!you said left bank joe, is it a V8 or the all mighty straight 6?/emoticons/[email protected] 2x" width="20" height="20" />
When you say you sunk it, how far did you sink it? above the hood?
When you said it wont turn over, you mean its not cranking or it cranks but doesnt start?
First thing i would do if you even suspect you have water in your motor is pull all the plugs and try cranking it.
WATER WENT OVER THE PASSENGER SIDE OF THE HOOD. IT CRANKS, JUST WONT START.I HAVE A 1989 BRONCO TOOK IT MUDDING. SANK THE FRONT PASSENGER SIDE PRETTY GOOD. ACCIDENTALLY SHUT THE KEY OFF IN THE MUD, NOW IT WONT START ANY IDEAS?
CAN'T GET ANY SPARK AT ALL.WATER WENT OVER THE PASSENGER SIDE OF THE HOOD. IT CRANKS, JUST WONT START.
Where is your coil located? If you had water over the hood, it's possible the coil was soaked as well. This would definitely cause the problem you're having. Check to see if your battery is providing power to your coil, and then check if your coil has any power coming out of it. This should be a pretty easy way to figure out why you don't have any spark.CAN'T GET ANY SPARK AT ALL.
ALREADY REPLACED THE COIL STILL NOTHINGCAN'T GET ANY SPARK AT ALL.
