lossing power
ms_jetset
Redneck & The Bronco
The Big Apple:-( N.E. Pa on wkends:-)
I started losing power once I put my lift and larger tires on. I'm worried I may be harming my engine or tranny. Should I consider putting in a different rear and if so how much am I looking at? Also I'm getting a loud clunking noise when I put her in D or R. I think it could be the U-joint?
ms_jetset,
your truck most likely came with 3.55 gears. That means that the driveshaft turns 3.55 times for each revolution of the axle. The tire turns one revolution each time the axle turns one revolution. WIth 31 inch diameter tires your truck would move 97.34 inches, with 33 inch diameter tires your truck would move 103.32 inches. I don't recall the formular for torque, but suffice it to say that it takes more engine power to turn those larger wheels.
With that being said, you should have noticed an immediate loss of power when you put the larger tires on, not a gradual loss. That loss should have remained constant. IE if you had a ten percent percieved loss in power with the new tires on, that should not change. The loss is stricktly due to the mechanical advantage loss of the engine to the rotation of the larger tires. I know I wrote that ars backwards, but it is technically correct.
Also, it is my understanding that a lifted truck has worse aerodynamics than a non lifted truck, therefore you have greater drag with your lifted truck than you did before. I believe that drag geometrically increases at higher speeds. But I know nothing of fluid dynamics, however at speeds greater than 30 MPH much of your energy is being spent trying to overcome air resistance (drag). So with a lifted truck you may notice more loss of power at highway speeds, but not at speeds less than 30MPH were there is little wind resistance.
Going back to gears, if you change your rear end, (that big round pumpkin in the middle of the back axle) and hence change the gears, you can restore the percieved power of the engine. The 302 and 351 engines have the most torque in the range of about 2,000 to 3,000 RPMs they idle at about 650 RPM. If you change to 4.10 gears, that means that the drive shaft will turn 4.10 revolutions for each turn of the wheel. That gives a greater mechanical advantage to the engine turning the driveshaft, which will counteract the advantage you gave to the tires when you put larger ones on it.
You may have noticed that your truck when in overdrive at 65 ran at about 2500 RPMs, and now with the larger tires, it runs at 2200 RPMS. At that speed your truck is still within its power range, but if you are at 50MPH and in overdrive, you may be at only 1600 RPMs and your engine does not have as much power there. Your stock tires may have kept the engine at 2000 RPMs at 50, it would have had more pep. I just made those numbers up, but I think you may get the idea.
I have a slightly older truck with a 302 and 33's on it. If you want to come over and take her for a ride to see if there is any difference between mine and yours for a comparison, that would be fine.
Oh.. I went on and on here... but I meant to say that if you seem to have a continued loss of power beyond the instant loss due to the change in tires, then you should check for diagnostic codes to make sure that your engine is running properly.
joe
M
ms_jetset
ms_jetset,your truck most likely came with 3.55 gears. That means that the driveshaft turns 3.55 times for each revolution of the axle. The tire turns one revolution each time the axle turns one revolution. WIth 31 inch diameter tires your truck would move 97.34 inches, with 33 inch diameter tires your truck would move 103.32 inches. I don't recall the formular for torque, but suffice it to say that it takes more engine power to turn those larger wheels.
joe
Joe-
I'm sorry, I meant to say an immediate loss as soon as I put the 33's on.
M
ms_jetset
Here is a great thread on regearing...http://broncozone.com/forums/index.php?s=&...ost&p=64103
Regarding the thunking noise, I think that would be easiest for a mechanic to check it out on the spot. It could be in the rear, or one of your shackles.
Maybe other stuff too.
I know its not the shackles cuz I just replaced them all. It only happens when I put it in drive or reverse or sometime when its already in drive btwn 15 and 20 miles per hour.
I don't know what it is, but it is NOT your ujoint. If it was, and it was that bad, you would have a horrible vibration whenever you stepped on the gas.
I 've got a small vibration in the rear sometimes when I'm on the gas, but if I let off and get back on it, it go's away.
I've seen this suggestion a few times in the past.
Assuming that you have autolocking hubs, put your truck in 4x4 and lock your hubs, then drop your rear driveshaft, and drive around in front wheel drive. If your problems go away, then you know that it is in the rear drive train.
If you have manual locking hubs then you could drop the drive shaft first, it won't matter.
I *think* I read a post one time that mentioned that with a lifted truck that the rear springs could ride up or something, when torque was applied to it due to accelleration, if that was the case, could it allow the rear axle to be out of alignment with the rest of the truck and cause a vibration? I'm thinking that it could, and that it would self correct when one let up on the gas pedal. But just for clarification here... I am not speaking from first hand experience with this, nor do I exactly recall what it was that I read. So please take this with a grain of salt, but when all else fails, you might suggest this to someone who *really* would know.
Sufferedformula
