B-Cack
- Joined
- Nov 23, 2004
- Messages
- 102
- Reaction score
- 0
OK, I always seem to get some really good advice from everyone on here, so I have a couple more questions to ask. First of all, has anyone ever replaced the ABS front wheel sensors on their Bronco? I have a 93 and was looking in the Haynes manual, it says that you simply disconnect the wire from the harness assembly, and then remove the one retainer bolt and slide the sensor out. Well, I removed the bolt, but the sensors do not seem to want to budge. Just wondering if there is another type of assembly, I'm sure with my luck that it will require complete removal of the wheel and hub assembly, but just thought I would ask before I did that.
My second question is in regards to the engine at idle. I have recently started to notice the at idle speed it began to idle high ( approximately 2500 RPM ) and would be normal under driving conditions. I replaced the IACV and it seemed to work for about a month, then just recently it began to idle low ( under 1000 RPM at stop lights and then stall out.) Today I replaced the EGR solenoid as well as PCV valve. I cleaned and re oiled my K&N filter and took the old Bronc for a test drive. It seemed to be fine idling, but I did notice once in a while I would press gently on the gas and would get a momentary drop in RPM ( for about half a second) then it would resume operations as normal. So if anyone has any advice on this I would appreciate it, thanks guys
