Pre ignition catalytic converter
321 bronco
Washington, DC
can any one tell me if a pre ignition catalytic converter #1 works on a Bronco and #2 if it actually gives better miles per gallon.
Well, if it they *do* work then it'll work on a Bronco just as well as it will on any other gasoline powered vehicle but I honestly can't see how ANY exhaust componant (with the exception of O2 sensors and such) will effect your milage. That would be like a muffler claiming to improve milage
madmax
quakertown pa
well a muffeler that is less restrictive would save a tiny amount of gas, simply by needing less power to push the exaust out the engine, still it'd be tiny, and burning the gasoline in the exaust rather than not burning it in the exaust, woupld likeley do nothing at all.
But that's a double edged sword. Anything that you would *maybe* save in fuel would be offset by the loss of torque & HP. Either way, I will adroitly sidestep the entire "muffler milage" debate & instead simply state that this Pre-Ignition Catalytic Converter looks to be an even bigger scam than the Tornado, the 100MPG carb (you know, the one the Govt & Oil companies are hiding from us), and who could leave out those cute little $15 magnets that attach to your fuel line.
Read up & decide for yourselvs: http://www.preignitioncc.com/monroe/
Caveat Emptor
89eddie89
charlotte nc
ive heard about the pre ig. and i was told that the mpg's, from what they could tell, hardly increased.
321 bronco
321 bronco
Washington, DC
thankx for the reply guys. BB (94 black and tan Eddie Bauer) will be going into the shop within then next two weeks i believe for dual exhaust flow masters and some other minor work. wish her luck.
eholt80
