Converting 89 Front End to 94
Bukd
San Luis Obispo, Ca
I have an 89 Bronco. I am wondering if it is possible to swap the lights/grill/front end to a 94 Style. I like the look of those better. If it can be done what parts would I need? Thanks for any help in advance.
Josh
BB33's
Rancho Cucamonga CA
Hey welcome to broncozone(I see it was your first post). The swap you want to do is fairly simple and not too expensive. Here's a rundown of the parts.
1992-1996 Hood
1992-1996 Grill
1992-1996 Driver and passenger Headlight Assemblies
1992-1996 Driver and passenger Fenders
1992-1996 Lower valance
1992-1996 Front Bumper w/wo plastic moulding
1992-1996 Bumper Brackets
Frontend Repaint to match
All this can be done for around 1200 give or take. My Dad Owns a Truck Salvage Yard and that price is for used parts in good condition.
Hope this helps(and if anybody sees something I missed fill him in on it)
B)
Yup, as you've been told it's a fairly simple deal. The only additions I would make is that you'll have to repin the headlight connectors for the hi-beams to work correctly and I would *definately* replace the nose as an entire clip instead of piece by piece. Now that assumes you can beg, buy or bribe a couple guys into helping you swap one for another but by changing it as an entire clip you save a WHOLE bunch of time. You *can* do it piece by piece but it will probably triple the hours you'll put into it. Now if you're like me & have more time than money that's just fine but if your time is valuable, buy some beer & call some friends.
Bukd
San Luis Obispo, Ca
I def. Have more time then Money. HAHA. So I don't mind doing it piece by piece. I just want to get it done. Thanks for all your input Guys. I will post pics and do a write up, So if other people want to do it, they will have a guide of sorts to work with.
Like the others said, it's doable but you'll have to swap the entire front end at once since the pieces are not interchangable. I think Blade262US did the "front clip swap", might search for his posts on the subject, JSM84
BLADE262US
Michigan
I have done this swap there are pictures here somwhere . Other things you will need are the core support its different for the headlight mounting . And you will need some angle iron to weld to the inside of your frame so that the 92 bumper has something to mount too . Youll be way farther ahead to find a complete clip to swap theres alot of little brackets that you will need to collect if you do it piece by piece . :D /emoticons/[email protected] 2x" width="20" height="20" />
eholt80
