5.0 EFI to C4 kick down?
73AZBronco
I have a '73 with a 5.0 EFI out of a '91 Mustang GT. The tranny is a stock Bronco C4. I do not have a kick down cable or rod from the motor to the tranny and I don't know what part/parts I need. Help!! If any of you out there in Bronco land have done this before and have a solution I'd love some info on how to hook this up so the tranny will kick down when needed. Thanks in advance.
Crude dude
Phoenix, AZ
Just checked, go to BCBroncos.com and look for the "fuel" folder. After you click on that look for the "EFI" folder. Hope that is what you need.
73AZBronco
I looked at it and all I can find is a throttle cable, although they do mention in their instruction library a kick down cable so it might be what I need. I'll give them a call tomorrow to see what's up [-o< . Thanks Dude! I'll let you know what I find out.
73AZBronco
Scratch that last post. I just found the page with the kick down cable. I think that's it. Hopefully problem solved. Thanks!
Crude dude
Phoenix, AZ
I assume that you are in Arizona? What part? I am in Central Phoenix. I have a lot of parts that I do not use so if you ever need something look me up. I may have it or can tell you where to get it.
73AZBronco
Yep, I'm in the far north Phoenix area. Thanks man.
david@holycitytransportat
