alignment issues
broncodriver33
Palmyra, Pa
i have a 93 bronco 2.5" lift and when i back up the top of the tires camber in. i just installed new ball joints and adjustable camber caster bushings. when i go straight they are at perfect 0 degree camber. does anyone have an idea why they camber in when backing up.
Did you use drop brackets for the radius arms and axle beams/ If not, you may be out of range of the bushings. May also have some wear in the suspension, like the axle pivot bushings or steering linkage. JSM84
Well gosh, JSM84 said what I was gonna say.
broncodriver33
Palmyra, Pa
yeah i used drop brackets on the radius arms and axle beams. i guess i will have to take a closer look for wear. i still need to get an alignment done do you beleive that could have any affect on that.
Yes, you need to have an alignment done on the front end after installing any lift kit.
Coastersfwb
