Engine change
newguy
I'm getting close to installing a '92 5.0HP into my '73. Just the basics under the hood. Alternator and power steering (no A/C or smog pump) so only 2 belts. I am having trouble getting an answer on the correct crank pulley. Would a basic 302 crank pulley line up the belts properly or do I need one specially for a 5.0? All of the 5.0 pulleys I see are for a serpentine belt. Do I need that with such a basic set up?
Any help would be greatly appreciated
swampthing
go to a junkyard and search around for an older car with a 302 that didnt have AC or smog pump that will be your best bet
N
newguy
On the Bronco Graveyard web-site I found a crank pulley for an 80-86 Bronco 302 engine with no A/C but no mention of a smog pump. It's $25 vs $85 for a the polished aluminum one that they have in the early bronco section so it might worth the chance.
Thanks.
swampthing
or if it comes down to it search around go to a local speed or performance shop and talk to them about underdrive pulleys...look good do the job and add a little hp
eholt80
