1985 Bronco
George Harms
Englewood, Florida
My 1985 Ford Bronco runs great for a while. Then it starts to sputter, choak and then it dies. I have replaced the fuel pump, filter, motor, carbeurator, plugs & wires. I am ready to trash it but my wife loves it. HELP!
bidibronco
Norfolk Va
Seems like you need a better description of what it's doing. Anything can make it sputter, choke and die... How's the carb look?
Roadkill
Killeen, TX
Could even be a choke problem. But we need a little more information. Which engine, (there were 3 available in '85) how long does it run before the problem starts? Will it start back up when it dies? You say a "motor" was replaced; which one? (starter motor, the engine itself?)
G
George Harms
Englewood, Florida
Thanks for your reply. I have an electric choke, Holley 600. 351 Windsor. Any time it's in gear, full throttle it will stall before 70mph. If I drive normal, it's sporatic. If I come to a complete stop, it will restart right away. It might run 5 minutes or it might die right away. The engine was replaced with discount auto parts remanufactured.
G
George Harms
Englewood, Florida
No rhyme or reason. Sometimes it runs fine. Always at full throttle before 70mph, it dies.
RBuffordTJ
Norris, SC
Have you checked the tank for trash, I had some in an old truck of mine years ago and the more gas I tried to give the harder it choked. The trash might not be near the fuel line but after a little bit of suction in the tank it will move. Just something to consider.
Roadkill
Killeen, TX
That is a good idea. If you had the same symptoms before the engine and all that other stuff was swapped, then the problem must lie with the remaining original parts. I have seen the same problem on a car that was left parked near a cotton field for over a year without a gas cap. The crud would **** up on the intake screen and starve the engine of fuel. Once the engine died, the stuff fell off and settled back into the tank allowing the engine to be restarted.
G
George Harms
Englewood, Florida
Thanks guys, I will check the gas tank.
Val
