adding a snow plow
timster24
CEDAR RAPIDS, IA
I am adding a snow plow on the front of my 88 bronco. I was wondering if anyone knows if a 2in front lift is enough? Is the weight of the plow gear going to bottom out the front constantly (700-800lbs). Currently I am running a stock suspension, with a double shock. Thanks
firelt90bronco
Ask me about my job
northeast
I have a 2001 Western Uni-Mount on my 90 Bronco. I use the Airlift 1000 airbag kit. Stay away from the airbags they blow way too easily. It really dosen't need a 2 inch lift but it would help with putting the blade up and hitting a bump. I find that when I cross an intersection the blade scrapes on the ground. The truck will not bottom out, it will squat like crazy.
Heres a pic of mine with the plow:
T
timster24
CEDAR RAPIDS, IA
I kinda wanna cut down on the squatting a bit, right now the front only has about 1.5-2in clearance from the bumpers. I really dont wanna be riding on those all night. How low the plow sits will be compisated by the plow rigging that I am welding up. Basically I am bumping up my "A" frame higher than Meyer had it. The attachment point will be raised up and tucked up next to the bumper, is what the design is looking like so far.
But I think I am going to throw a lift under the truck anyways, just to make sure everything is good.
I am running a meyer 7.5 sometimes the 8ft blade with a e60 quick lift pump.
Hey we do have a few old westerns that we are thinking of selling.
gnarly_bronco_kid
Lead foot
Midway, Utah
If you wanted to lift up your front end the cheap way for that plow you could just get some of those coil spacers. they're cheap and easy to install. And hey while we are in the subject of bronco's and plows. I found a bronco for sell with a 351 with a lot of rust and it has a decent plow on it all for 500 bones. you guys thing it's worth it? I'll get some pics on here tomorrow.
Zak
kevinmach1
I just added a western plow to my 1990 bronco, and I got a set of stock front coils for a 1990 f-150 ext cab 4x4. The springs are a dual rate spring, have a few more windings and are a bit longer than the broncos springs. It raised my front end up a good 2 inches and the ride is way better than with the stock bronco springs. I got mine through a local auto parts store, AC delco brand believe it or not, for 68 bucks.
T
timster24
CEDAR RAPIDS, IA
Kevinmach1, was there much saggin with those springs. I know there is going to be sag I just dont want lots of sag like some of the other trucks i see running around this area.
gnarly_bronco_kid
Lead foot
Midway, Utah
Alright so Here's the bronco I was talking about. I might buy it and part it out along with the plow because I know plows aren't always cheap. The truck runs "not sure how well" and the plow is functional. I can always repair the trucks running condition but if not I can part it out.
The entire truck and plow for $500............you guys think it's worth it?
kevinmach1
The stock springs were a little bit "lower" than the rear, with a bit of a rake. With the new springs, it now sits level and is much more "supportive" of the weight of the plow. I also have the dual shock set-up, like you have. Like I mentioned before, It rides much better than the old springs. I wasn't expecting that. B)
T
timster24
CEDAR RAPIDS, IA
cool, think I might try that out, thanks.
qnarly bronco kid--dont look to bad, a truck like that might be worth either parts or a plow truck. The only problem with a plow is lots of times they are all rusty and beat to death. but for 500 you could make a few bucks off the truck. But personally I dislike the cable driven western plows. But they work. So I would almost pick it up and runn it. **** it could have a nice strong 351 if nothing else.
kevinmach1
Timster24,
I just noticed you are from CR. I got my springs, the Ac delcos from Tom at IWI in CR. Give him a call and tell him you want the same springs that Kevin at Raincap got from him.
Good luck.....
T
timster24
CEDAR RAPIDS, IA
ahhh thats where you got them, I picked a used pair yesterday at Olson's. And threw them on a couple of hours ago. I do like how they sit. I just have not welded up my plow gear yet, so will see how they do when dangle that off the front end. It did level out my truck and I like what I see so far, so I think it might be nailed. Thank You!!
now I got to figure out hydraulics LOL
Plow/Truck
I have a 73 Ford F 250 (3/4 ton) 4x4 long bed truck, and with the plow mounted on its quite long.
To make matters worse this truck doesn
firelt90bronco
Ask me about my job
northeast
I like plowing with a bronco, you can get in and get out fast. The size makes it easy to manuver in tight quarters.
ilystbronco
long island NY
u dont have to lift it all u need is air helper springs up front, they are only like 80 bucks and u can find them at a snowplow website.
firelt90bronco
Ask me about my job
northeast
Air springs **** mad balls! They can dry rot and leak, they get damaged easily and I wouldn't ever run them in another truck again.
Broncosaurus!
Oshkosh WI
Any before and after pics of the bronco with the 1990 f-150 ext cab 4x4 springs? I would like to do that with mine, my bumper weighs it down a bit and you can't get too high
tsebalj
