rear wheel bearings
bathesda49008
S.W. MICHIGAN
I'm having trouble getting my rear axel to fit completly into the differental. driver's side seems ok but i can't seem to seat the
other side when i put it in gear i get a horrible gear grinding sound from the rear end. If anybody could help it would be aprciated. this is a 1979 with a 460 swap.
Thanks
[email protected]
Justbust1n
walkertown
I'm having trouble getting my rear axel to fit completly into the differental. driver's side seems ok but i can't seem to seat theother side when i put it in gear i get a horrible gear grinding sound from the rear end. If anybody could help it would be aprciated. this is a 1979 with a 460 swap.
Thanks
[email protected]
you might want to chek the differiential bearings and the spider gears for missing teeth , while you got it down ...
Are you sure you didnt mix them up, drivers side in passenger side vice versa?
Sandoval_broncosauria
