I have a 1996 Ford Bronco, 5L (302), auto transmission, with 123k miles. I got a "check engine" light display one day. Took it to Checkers and had it tested. Code was P0401, for insufficient recirculated gas. I got a new EGR valve which included the gasket and two "washers" which act to restrict the flow into the EGR valve. They are slightly different size. Each had a different number stamped into it which I assume was cross sectional area of hole in the washer. I removed the old EGR valve and noticed there was no "washer" installed betw the tube and the EGR valve, so I did not install either of the washers provided. 3 minutes later I got the valve installed, engine running real nice and thought my problems were over. Not so fast. After 30 or 40 miles the check engine light came on again. No sweat - I had it tested and it was a P0402, too much recirculated gas. Hm....I installed the smaller of the two washers. Miles later same check engine light came on - but this time it was a P0401 - insufficient recirculated gas. So here I am laughing and wondering to do next. Now each time I touched the EGR valve, I disconnected the battery for safety adn to clear the memory. Also my EGR valve does not have the position sensor attached to the top of it, it is located in some as yet unknown place.
I ordered a new EGR valve position sensor from Autozone, but I need some help here. Where the heck is it? I looked everywhere, but can't find it. Hopefully it is not betw the rear of the engine and the firewall. It appears to be about 2 inches tall, black plastic, a plug for the electrical connection and at least one connection for a hose - maybe vacuum line??? Dealer charges $128 and I paid $23 plus ship/tax, so I am in the right price range.
2nd question is if I can get that sensor installed and the light comes on again, too little or too much recir gas, any ideas what to replace next ? EGR pressure sensor maybe???
The truck runs real nice now, mileage went up 2 maybe 3 mpg. If light comes on, I might just ingore it with some black tape. Bad idea?
Thanks in advance for your help. YOu guys provided some good info the last time.
