First timer her so Hi to all.
About 6 weeks ago, I picked up a 95' XLT, 5.8, 144,000 miles, manual hubs, E4OD trans I believe, open rear axle
( . I took it straight to local shop and they replaced the front rotors and brakes adjusted the rear and flushed the brake lines, flushed cooling system, and a trans flush. Runs great except for two problems I am now havng.
First, after running some very short stop and go errands, both my front rims where very HOT to the touch, both rear where fine.
Second, I noticed the temp gauge register quite hot and checked the level of the coolant. I had to add about a gallon and that brought the temp way down. Since I just had it flushed I figured it was full, and no external leaks that I can see. So, would this suggest a head gasket leak?
Also, anyone know where I can pick up the lower outside rear window weather stripping?
Thanks
Thanks
