MLP out of Sensor - Code 634
Macdaddy_2006
Hey Guys:
I'm fairly new to the Bronco world - we got ours probably 6 months ago from a friend who was thinking about trading it in.
Anyhow anytime I start the car and try to put it into a drive I really have to give it some elbow grease to get it past reverse.
Than at times when the car is left on an angle (in park) for a little while it will have problems shifting into gear and than when it does the RPM will drop very low and it will stall. Eventually it will start again.
I plugged in the code reader and got code 634 - Manual Lever Position out of Sensor - I looked up it up in my repair manual and it doesn't look like too hard of a job to do the adjustment myself. It looks like I'll need a speacial tool though.
What do you guys think is it an easy job ?? Can I do it myself ??
Also any idea what these Broncos weight ?? I want to get some jackstands to do the job myself but am not sure on the weight.
yo!
yes, DIY jon\b!
Try troubleshooting the MLPS
E4OD Manual Lever Position Sensor (MLPS) article by Pete via Ryan!
http://fordfuelinjection.com/files/Ford_MLPS.pdf
Try aligning MLPS marks as hown here:
E4OD MLPS pic w/Alignment Marks (from a Mercury, but similar) by Steve
http://www.supermotors.net/vehicles/registry/media/81709
for more MLPS info Links incl the alignmt tool, look here;
http://home.comcast.net/~miesk5/BroncoTech...tm#Transmission
under E4OD MLPS
& usually the MLPS sensor is replaced because they do go bad & there are no rebuild parts.
Shop for $ at www.rockauto.com and then try to have local parts shops match or beat their price.
code for a 5% discount at Rock Auto Parts is 253062243271
see if it is still valid
Why a Transmission Range Sensor May Fail
Time and usage
Prolonged use in extreme temperatures
If the electronic circuits to and from the sensor and to and from the engine control computer module are malfunctioning
by Ford
Weght; 5,450 pounds for our 96 Xl which has nerfs, push guard, Tuffy console, pw/ddl, about 100 lbs of tools
eholt80
