1990 Bronco push button 4wd
304Thomas55
Wv
I bought a 1990 Bronco E.B. with 302/AOD. I don't know which transfer case it has. Buttons on dash don't work. So I'm wondering if there's a conversion to put a lever installed the way trucks use to be. I also want to go back to locking hubs. Thanks in advance
Broncosandpartsgarage
Michigan
It’s a BW1356. You can just swap in a manual tcase too. Easier than drilling case for hardware. Check the motor on the tcase. If bad replace.
wyo58
Laramie WY
So what is the manual transfer case model number ?
It is a BW 1356 as well just manual shift. you will also have to get the shifter, boots, and shifter rod. Your floor board has the cut out already just take the screws out of the blank cover and use a hot air heat gun to remove it.
304Thomas55
Wv
Thanks Wyo58
Jimbo26
Texas
Thanks Wyo58
Pricey, but looks like its made to make things happen. If it wasn't for the 💰
would have seriously looked into this.
304Thomas55
Wv
Yes $$$. I found the manual 1356 close by with everything $200. Has 82k miles on it
Val
