'90 E4OD wont shift properly
Hway
Paragould
I have a '90 full size with a e4od transmission.I had it running doing 70 that was 2 years ago. I had to let it sit for a bit because of my surgery, then I took it out for a spin and I can't get it above 35 again.
I have changed parts over time.
I have changed the sensor on the pumpkin, changed the speedo gear, changed o2 sensor, alternator and a few others.
I even had it at transmission shop, they said it wasn't getting enough power but it was good.
Then I hit a bump then it was working right.
However since it sat for 3 months I can't get it running right.
It sounds like it is an engine issue, not a transmission issue?
Not enough power to get enough speed or rpms to shift? Does that make sense.
Or what is it that makes you think it is the transmission?
H
Hway
Paragould
The rpms is going high but will not shift. I thought when I took it to the transmission shop it would be transmission. They said it was good but it was the lack of power. I do know in later models a 3rd brake light would make it go in limp mode, so I checked all of my lights and if they were out, I replaced lights.
I'm not a mechanic but I'm willing to try to fix it.
Coastersfwb
