Best way to access HVAC control panel
cporan
St Augustine FL
What is best way to gain access to the back of the HVAC control panel and the vacuum control switch?
I have removed the front panel, the radio, and the ashtray. However I cannot see how I can pull out the controls to gain access to the vacuum control switch and tubing to see if there's any damage and if it is working properly.
The reason I need to do this is because my defrost and floor heat are not working. The only air for heat or AC is coming out the dash vents.
I have not found any YouTube videos that show me how to do it.
96XLT
Springfield, VA
Try this video, it is a HVAC control repair bracket, but shows how to remove the HVAC control.
C
cporan
St Augustine FL
Thanks but that doesn't apply to my truck. I have a 1985 bullnose Bronco. It has a totally different dash and HVAC controls.
96XLT
Springfield, VA
It has been about 25 years since I had to get rid of my 1984, but I vaguely recall two screws to remove the cover and 4 screws for the HVAC panel - removing the stereo to reach through to detach the cables and plugs.
At the bottom of this page there are two video replacing the HVAC control: https://forum.garysgaragemahal.com/topic/11216-next-issue-heater-air-flow/page/3/
Here are some 80-86 HVAC diagrams: https://www.garysgaragemahal.com/hvac-systems.html
Vacuum diagram: https://forum.garysgaragemahal.com/topic/11961-vacuum-lines-for-hvac-door/#comment-159900
This video seems to state you can remove the vacuum portion from underneath by removing the ashtray: https://forum.garysgaragemahal.com/topic/11219-repair-of-an-hvac-control/#comment-143711
Good luck.
24Rocko58
