92 Bronco F250 Chassis and 5.9L Cummins Diesel Engine Swap - Documented build thread
Shaggy
Administrator
Arizona
Can't wait to see this thing come together. When will you be getting the gauages again? Sorry if you said it and I missed it.
Scottburgesscpa
Houston
Thanks!
Not sure...waiting on LCD screens from China...probably about 4-6 weeks! Making a few minor changes to the gauges but they're definitely getting close!!
Scottburgesscpa
Houston
I am so excited! I picked up the custom aluminum fuel tank from the welding shop! It should hold somewhere between 34-37 gallons. It is designed to fit between the frame rails behind the rear axle. The "wings" on each side will bolt to the frame rails. We used gussets to strengthen the mounting brackets due to the sheer weight! This will definitely help to put some weight in the rear end (270-300 pounds when full). There was one additional baffle installed that has not been pictured. We have 3 (-10AN) ports on the sump because, of course, the first port is the supply line port, but according to the engineers as FAAS, the fuel pump needs a dedicated return and then there needs to be another return from the fuel rail on the engine. I hope y'all like it! Let me know what y'all think!
Scottburgesscpa
Houston
... continuing to work with the guys over at OneGauge.com to finalize the dash gauge layout....
Scottburgesscpa
Houston
Finally got the final instrument cluster design all mocked up...we played with photoshop a little bit to put the picture of the gauges into a picture of the actual F150 dash bezel it's going into!! LMK what ya'll think!
Yo Scott,
Looks great! Hopefully the bezel won't be prone to damage when removing for repair as the originals suffer..
92-96 Cluster Bezel Repairs
"It's common for the clips across the top snap off their mounting posts, but the posts are hollow, so it's fairly easy to install a *****. The hardest part is getting the final 1/4 turn on the ***** so the clip stays tight.
It's even more common for the ***** holes behind the trim strips to break out, but it's easier to repair them. I used this plumber's strap to hang some hardware for powdercoating, which is why it's black. But since it'll be totally hidden, plain strap is just as good. Even if the holes haven't cracked yet, this mod will prevent them from ever breaking" by Steve
Keep on keeping on Scott.
Scottburgesscpa
Houston
Yo Scott,
Steve,
Thanks! Actually, I'm getting rid of the entire dash from the Bronco and putting in the entire interior from a 2011 F150 Platinum.....seats, console with floor shifter, complete dash....everything!!! That oughtta fix the problem!!
Scottburgesscpa
Houston
So don't know if you will be able to view this video of my working instrument cluster, but here it is! This was just a test run by hooking it up to power to test it. I finally started removing the bronco body from the chassis last weekend and hope to finish this weekend and have some pics for y'all. Also pretty cool...I bought a bronco Remote Controlled truck and I am fixing it up and painting it to be a miniature version of my big one so I can play with colors and designs...I'll post some pics next week! Thanks for everyone's positive comments and feedback so far! Enjoy!
