Pillar Gauge Mount for 93
RR-Texas
Houston, Texas
I was wondering if anyone was aware of a pillar mount for gauges, 4 Wheel Parts told me to check with Auto Meter so far I can't find anything? Found some listed on a different parts site, but they were for newer trucks. I would like to find a 3 gauge mount, prefer not to have to mount them under dash.
Thanks,
Richard
RR-Texas
RR-Texas
Houston, Texas
Heck I just found a few, must have been the way I typed in the search words...never mind
I would delete the post but don't see a way?
brad6920
Magalia, CA
Yeah, but just in case someone else wants them, you can get them at Summit Racing. They have 2 and 3 guage pillar mounts for '92-96 Broncos and trucks.
RR-Texas
RR-Texas
Houston, Texas
I have been checking the links, however isn't the dash solid? I want to run a manual temp gauge, oil pressure and maybe trans temp in the pillar mount. Not sure about the trans if it is manual or elec., seems like a lot of stuff to route downward? Once I get it under the dash I am ok
Xxxyank
Lake Norman, NC
I been playing with the Idea of a trans temp and Tcase temp. I just can't find the gauges that i like... One of the major companies went out of business (starts whith an N), they had an awesome set up. So if you find something post some pics.
yo RR,
To me, "pillar" is the A pillar that is vertical along windshield.
So, are planning to install gaudes there and in dash?
Such as this Dash Mounted pic in an 89?
Source: by Mike K
or
Dash Top Mounted pics in a 93
Source: by Va92bronco http://www.supermotors.net/registry/15518/54577
or
Drink Holder Mounted pics in a 93
Source: by Fred K (Alphabronco)
RR-Texas
RR-Texas
Houston, Texas
miesk5 I bought one of the 3-gauge A-Pillar mounts, not much of a body man so I am unsure about routing the cables/wires etc through the dash? I like Fred's dash top mounts as well as the ones mounted in and across the 93 dash is a very nice set up as well!
The drink holder is a cool idea, however my Starbucks addiction, I mean my casual,once in a while Starbucks purchase would not allow that as they are usually filled one for now and one for later. I had forgot about a Tcase temp gauge, although I have not yet gotten the off road bug.
yo Richard,
re your Q; "... routing the cables/wires etc through the dash?
see my prev replay;
Locations to route new wiring, tubing for gauges, etc
such as; Clutch Blank Location pic (to route new wiring, tubing for gauges, etc.) in a 96
and the pic I took in my Bronco
it is http://broncozone.com/uploads/monthly_10_2012/post-3816-0-26637000-1350822748_thumb.jpg
Clutch Blank Location pic (to route new wiring, tubing for gauges, etc.) in a 96; Located next to master brake cylinder booster; drill through from engine bay, higher the better; then seal use a grommet & RTV or other sealer to fit hole and big enuf for all wiring & a vacuum hose to install a vac gauge; best low-cost test and MPG helper you can spend $ on
AutoParts2020.com - Gas Saver Vacuum Gauge, PM1520, 2 inch; & many parts & accessories
http://www.autoparts2020.com/rsdev/part_detail.jsp?PART_HDR_ID=87069
or;
Driver's Side Location pic (to route new wiring, tubing for gauges, etc.) in a 91
Source: by California Monkey (Richard, Mama Cass)
http://www.fordf150.net/images/mytruck/vacgauge.jpg
ALSO CONSIDER A GAUGE POD MOUNTED ATOP DASH IN CENTER
Gauge Cups, Panels, and Pods
http://www.jegs.com/c/Gauges-Tachs_Gauge-Cups-Panels-and-Pods/10335/10002/-1
such as
Triple Dash Pod
Universal (8.4" W x 3.5" H x 4.5" D)
For 2-1/16" Gauges
Black
http://www.jegs.com/i/Auto-Meter/105/5288/10002/-1?parentProductId=
Coastersfwb
