Which lift kit is best?
brad6920
Magalia, CA
I have a '94 Bronco and am putting a 6" lift on it soon. My questions are:
1) Should I get the Superunner Radius Arms?
2) Should I get new leaf springs or just helper springs?
Any advise here is appreciated.
DNBELOWBRONCO
CALIFORNIA
I would personally go for the full leafs or do a shackle flip with the stock ones. Make sure your lift has the 4" or 6" provision so you can switch if you want later. That way it's just springs and moving the axle housing bolt to the other hole. Radius arms is your choice, depends on how hard you wheel. Duff and Cage have nice ones, but man, $600+ just kills me.....I have a Rancho 4" with extended arms and it siuts me fine till the SAS later on. Make sure you do the drop pitman arm and look into the tie rod flip to the top of the knuckles too! Good luck man! >:) -Kevin-
Coastersfwb
