headliners
bigjohn
ga
just got a 1980 bronco and starting to work on it. but I can not fine a headliner for it can anyone help
Krafty
Ontario Canada
can you give us some more details on your bronc and project,
also my 81 came from the factory without a headliner
bigjohn
ga
it is 1980 xlt 302 on 32x11.50 with A/c it had a headliner in it at one time but can tell where someone took it out
Your best bet would be a auto parts recycler, but they may not be in too good of shape. An upholstery shop could probably make you one.
RBuffordTJ
Norris, SC
I have a 1984 FSB, my headliner is on a panel you can drop once you remove the trim. Just get some thin padding from our local craft shop, cut to fit. Same with whatever you want the headliner to be made of and they also sell a spray adhesive you can buy to stick it all together.
Sounds simple enough huh....
Bufford
bigjohn
ga
Bufford
yeap sound simple enough but only thing is who ever had before me took the whole thing out and I dont have the hard panel to put the padding on. but thanks for the help
bigjohn
bigjohn
You will probably have to find one locally, those hard panels are made of pressed foam and don't handle well, especially in shipment without special packing and box. Because of it's size the cost of shipping would probably be pretty high in spite of the fact that they are light weight.
Coastersfwb
