94 rear bench seat
kjp
I need a rear bench seat for a 94 xlt 5.8 bronco. Are there other years and models (F150) I can search for that would fit the 94?
All Bronco years 80 - 06 rear bench seats will fit. Your best bet are local auto recyclers.
Yes, ALL rear Bronco bench seats are the same and NO F150 bench seats will not fit,
Krafty
Ontario Canada
if you cant track down any bronco seats, dodge ram charger and blazer seats can be modified to fit with a little elbow grease and ingenuity.
yo
Shoulder Belt Addition to pre-92; "...You can buy a good used '92-96 camper shell for $20-100 any day of the week to get the hard points in the roof. But the rest will be a little more difficult. Finding good rear shoulder belts from those trucks is harder - I've only found 1. Then you'd have to drill & weld in 2 more hard points to mount each belt: 1 for each reel on each wheelwell, & 1 for each end on each side of the rear seat. Then you have to swap in a '92-96 rear seat, or at least '92-96 buckles. Doing it with a roll bar wouldn't be much easier, even though you could use ANY roll bar & just have some nuts welded in to recieve the shoulder bolts. You'd still have to come up with a belt system that you'd trust with your life (or your family's). I'd stick with using factory parts because you KNOW they meet DOT specs for rollover safety..."
Source: by Steve83
http://www.mypartshop.com/
Select All Parts
year, etc, then FORD TRUCK
Seat, Rear
Some results (PA for example)
94 BRONCO Seat, Rear XLT GY $75.00 Village Motors Inc 800-942-7688
94 BRONCO Seat, Rear GRY LEA $75.00 Newcomer's Truck Parts
717-762-1532
etc.
or
http://www.copartfinder.com
Has Vehicle Pics!
http://www.picknpull.com
http://www.car-parts.com/
Also for obsolete parts;
Our Sponsor here has been adding some to inventory; Jeff's Bronco Graveyard
and: by Ford pn:
http://www.partsvoice.com/
http://www.rearcounter.com
http://www.greensalescompany.com
K
kjp
Hey guys, thanks. found a 92 gray bench seat for $100. Thanks again for the info.
tsebalj
