I have been searching the forums for a fix but have not yet found a problem that seems similar to mine. The window works if you jump it directly at the motor. I have power on both wires to the motor on the volt meter if I ground the meter to the chassis of the truck but not on the 2 wires themselves. I assume if the volt meter is on the 2 wires I would get a + reading with the switch in one direction and a - in the other, but I get no reading either way. My thought was it was a ground issue but we cleaned 2 grounds; one behind the LH taillight and one under the dash. The dash switch was replaced very recently by the PO so I do not suspect that. Is the tailgate switch bad? I have bypassed the tailgate closed switch by putting a jumper from one lead to the other. I know I have to be missing something here because there seems to be know reason for it not to work.
