wrong VIN!
blackdog
Problem,
Bought "73 Bronco after research found the VIN that it titled under is from a "73 Ford F100" this Bronco was registered in two different states with this VIN. :angry: Found VIN on frame rail and of course not even close, and I have to get this beast registered.
Do I notify DMV in Tennessee where I am going to be living or try to get a corrected title from the state where it is currently registered, Florida still under previous owner title.
Thanks.......
S_bolt19
Colorado
if it has been signed over to you, then you should be able to get the title done in your name & state with the correct VIN. Is the VIN plate still on the glove box door and/or on the driver rear door pilar? If it is, then what you are probably going to have to do is a title search to make sure the vehicle isn't on a stolen vehicle list somewhere and then get it cleared that way. More pain in the rear because someone decided to grab the closest title they could find.
blackdog
29409[/snapback]
No glove box door and the on the drivers striker post is the VIN plate, which looks original for the 73 F-100.
Anyway thanks for the thoughts and I am going to contact the state DMV and see what they say?
Anyone else have any thoughts or have this happen to them I would like to read your solution/fix.
Tim
Banjo_Charlie
Just wondering how Tim's problem turned out.
I just got a '72 and the title is wrong also. The title say's "U156LP****" , the 6 should be the letter G. Should I have this fixed or just let it go? If I did try to fix it, what steps should I take, it is in Texas.
Thanks for any help
Banjo Charlie
Tim
eholt80
