Wiring nightmare...
Rusty351
Like I think I've said before, our Bronco had been re-wired from almost every angle by a bored tweaker with no electrical common sense & we are slowly finding more & more that is rigged...
Today, the tail lights remained on & smoke was coming from the dash. Come to find out that some of the wiring mess below was all melted into eachother....is this a common issue with the Bronco?? Any tips, hints, or help??
89Bronco58
Jersey
there was a recall on some year broncos, i believe around your year or your exact year , about the wires in the steering column to under the dash that would burn up, you should call ford and check and buy the replacement wires, that could be it
Rusty351
Rusty351
I'll check the stealership when it's not the holiday-thanks for the tip!
Coastersfwb
