windshield wiper problem
Devil Dog08
philadelphia pa
hey everyone hope things are well with you guys.things been good with my 95 full size until today . my wipers wont shut off. i have delay wipers all speed work fine . the washers work also . the only way to get them off is to turn the key off. any suggestions? thanks
yo DD,
Testing Diagram & Instructions in 92-96 Source: by Ford via Steve83 (Steve, That dirty old truck) at SuperMotors.net
NOTE: The ground wire test at the top is only for motors that DO NOT RUN normally.
http://www.supermotors.net/getfile/878621/fullsize/wipermotorrevised.jpg
Wiper Motor Connectors
Wiper Control Module (WCM) Location pic in 92-96; as Steve83 pointed-out, "...The module I MIS-labelled as "Airbag" is actually the Wiper Control Module (WCM). The Airbag Diagnostic Module (ADM) is light blue, wrapped in black foam, above the gas pedal..."
Source: by Ryan M (fireguy50) at fordfuelinjection.com
Diagnosis in 92-96; "...Why a Wiper Control Module May Fail; Electrical overload; The electrical signal to module is interrupted in any way; The signal it puts out is not interpreted properly by the wiper motor Related Components to Check; Appropriate fuses (see Shop or Owner’s Manual for fuse layout); Wiper/Multi-Function Switch (MFS); Appropriate electrical connections to the wiper motor..." by Ford motorcraft.com
btw, there was a WCM Lawsuit Source: by State of Minnesota lawlibrary.state.mn.us
Bronco Kid!
Silverdale Washington
hey im curious if your wiper switch is located on the collum with a lever if it is then you may have to pull the plastic covers off of your steering collum and 9 times out of 10 just replace the whole switch assembly..
Devil Dog08
Devil Dog08
philadelphia pa
well just got in from taking the covers off the coulum. .sprayed the contacts with cleaner waited for the stuff to dry. working fine now. i guess between all the rain and moister we are having here the dirt on the contacts caused this problem ..............thanks everyone for all your help
Sandoval_broncosauria
