window motors
Animal
Louisville, KY
i just bought a 1990 eddie bauer bronco and i found out the window motors dont work... my buddy has extra motors in case his motors break and their for a 91 bronco.... would i be able to put the 91 motors into my bronco and them work out fine???? lemme know thanx
Big Country
San Antonio, TX
the motors for the 91 should work fine. and once you replace them once it should be easy to manage them because the rivets won't be there anymore. Make sure you attach the motor with lock washers so the vibration of the truck doesn loosen the nuts and then you have a motor in the bottom of your door. :D /emoticons/[email protected] 2x" width="20" height="20" />
A
Animal
Louisville, KY
thanks guys i appreciate it alot.... i am just starting out on it so hopefully it will get better
Coastersfwb
