window cuts out sound
cj_92Bronco
RADFORD VA
has anyone run into this problem? when i put my driver side window down the audio cuts out. and when i put it up you can hear the audio coming in and out but its not totally back till the window is all the way up
If it's just driver's side speaker cutting out; pull door panel and see if the speaker wires are being chafed or the conn is loose
Krafty
Ontario Canada
that could cause the whole system issue, if the interference is going back through the ground on the speaker then when it goes back through the deck it would cause the interference, either way inspect the wires in the door panel.
I had a front speaker with a bad wire, but it would only cut out the front speakers, so it could depend on the deck
