what would u get??
mbtech2003
cape cod, mass
SOOOO the rear end gears that i put in 2 years ago have almost had it (they were from the junk yard so i'm lucky they lasted that long).
should i get a limited slip or stick with the open diff?? I don't do a lot of off roading mostly when theirs snow on the ground do i have fun or if i go out on the beach. i just don't know if i want to spend the money on a limited slip set up....but i do like to spin them now and then to breath in the rubber dust :D /emoticons/[email protected] 2x" width="20" height="20" /> ...god i love that smell nuttin like a smokey BFG tire burnout.
Any way what would u get??
Broncoholics
Broncoholics
Washington State
Well if you have the carrier out you might as well save up a bit and add a limited slip so you have a bit more traction off road when needed. This will not be as harsh as a locker and costs less. Don't get cheap and weld the spider gears as it will wear tires and cause them to curp arund corners. No good for street use.
bidibronco
Norfolk Va
I'd spend the little extra and get a limited slip... open diff's just arnt enough if you have to get new ones
eholt80
