Vibration/banging
coolio2281
Union City, OH 45390
i got my brakes fixed today on my 93 bronco, with the 5.8. all new pads, calipers, drums, shoes, the works, well my truck allways had a vibration and shudder when slowing down soo figured it was the brakes, well alot of the shuddering went away with my new brakes but there is a constant banging . seems as if there is a spike or sumthing in one of my front tires that is causeing the banging but idk what it is, and if i drive at like 30-75 there is alot of vibration coming from the front, my radius arm bushings are bad. this i know, cause bad radius arm bushings cause this? or what else could be the culprit? thanks guys ur the best
yo coolio!
LTNS PAL!
Yep, replace those RA bushings asap; too much force can bend da brackets and then...........
Also ck ball joints...
Shocks/bushings
etc ...
GL!
C
coolio2281
ball joints are new, and the radius arm bushing is just shot on one side, i had it all checked out today, but i found the culprit, but in finding a new culprit comes finding new answers, haha, so my front left hub is stuck in lock position, my front shaft is off and all my 4x4 electrical components arent hooked up , any suggestions? i caint drive to ohio like that can i? its causing a rotational thumping noise. the bad vibrations were the rear drums were warped and they are fixed now, just the hub needs looked at. but yeah its causing a thumping and at higher speeds its less noticable as far as the thumping goes but its causeing a vibration. but the hub get hot as **** after iam driving, can i just drive it to ohio like thaT? iam allready limited to cash for food, let alone for this truck, thanks again i really really appreciaite it due to i leave tomarrow at 7 am for ohio, and iam in florida, haha
AdamDude04
Well you won't be driving next to me on the highway..so I say go for it! :-"
C
coolio2281
haha, ***** it. it is what it is, times are tight have to make some sort of sacrifice sooner or later, just didnt think it would be like this, i found a cheap set of manual hubs for sale for 50 bucks, so iam gonna just take em to ford tomarrow before i leave and see if they can install em for me, that should take care of it. if not like it said, it is what it is, at least i have the problem diagnosed so when it does break down i'll be fairly certain i know the problem, haha thanks again guys, have a good one, and wish me luck!
