***** Varible Carb
chchma777
I have a '82 full size 351W and I need to replace the varible carb with a SMOG legal carb. What's out there. I thought I had the problem solved but the manufacture stopped making the TPS for the I-646 I almost bought. :blink:
varible_venturi
  • varible_venturi
Check out Edelbrock for a C.A.R.B./50-state legal 4bbl carb and intake manifold setup. If you want a stock 2-bbl replacement, try LMC Truck.
dicain
you can get a catalog on line from www.lmctruck.com its on of the easier places to find parts. what program did you use to post the picture?
If you decide to go to edelbrock, I have an aluminum 4bbl one for a 351W available that I took off my truck. It needs cosmetic cleaning, just dirty on the outside.
Broncoholics
Broncoholics
Washington State
I like the old Q-jets because they work off road at any angle. Edelbrock, Holley and the rest all flood out at nasty angles. For street use go with the Carter, I put one on years back becasue I couldn't pass emissions. I installed it and passed without even tunning it. Seemed to get good gas milage.
Sandoval_broncosauria
