Vacuum Canister?
tkocurek
I have a 79' Bronco that my daughter got into an accident with where I have had to replace the front clip to fix the damage. There is a vacuum canister that sits under the driver side metal inner fenderwell and to the front of the plastic inner fender lining that I removed a hose from but can not now find the hose or where it might have served. I have the vacuum canister that sits in the engine bay on the driver side fenderwell and all the hoses and connections are accounted for. What does this other cansiter serve??
highboy73
FORDing thru life
morocco,indiana
I can't believe noone has helped you yet,the lines all depend on the truck,air,all kinds of crap.I would go and check out other trucks and bronco's or go to a library and check the books they usually have them in the referance section and they date back too the beginning of time.
Ziggy
Riverside, Ca
The vacuum canister T's in at the firewall just behind the engine on the drivers side. The other side should have a check valve and then a line giong to the intake manifold.
Gary wilder
