turn sighals [again]
sandman90
Laurel,DE
Hey all, A wile back I posted that my pass.side front turn signal won't turn off.I switched the bulbs and cleaned up the grounds as suggested,still flashing! even with the key off,what next the switch that goes through the steering column?And does anyone know what color the wire is for pass.side front so I can check it for chaffing and a possible ground out?
Hey Sand man,
A chafed to ground will not cause the lights to flash. It will blow a fuse. Firsh check the flasher. They are cheep to replace, and I have had them do odd things. ( recently replaced one on The Beast that would work fine...then NOT! depending on it's mood I guess.)
If that doesn't work, look at your first post, and do as BullyBob suggested. Disconnect the wires from the Turn signal switch at the base of the steering column. If that corrects the problem, you have a malfunctioning switch.
Good Luck
Staff online
stevedave
