BigGreenBronco
Hi I have a 95 Bronco xl. Well this is how it started I was driving and the truck was running fine then it just shuts off and wont crank. I thought the fuel pump was blown because i couldnt hear it prime the engine it will turn over but wont crank also it has gas. So I check all of my fuses in the panel and they are good then i check the fuses under the hood and i found the fuse in position 22 is blown. this fuse controls the ignition coil, distributor pickup the powertrain control system relay coil and the thick film integregrated (tfi) module. So i simply replace the fuse and it starts fine then after i shut it off it wouldnt start checked the fuse and it was blown again each time i put a new fuse in it blows it i put a 40 amp fuse and it blew it too??Any ideas what could cause this?
