Transmission Swap
tship87
Maryland
I have a 93 Ford F150 and a 94 Ford Bronco. Is it possible to swap the F150 tranny into the bronco with no problems?
If the two trannies are 4WD, the swap is much easier. If the F150 tranny is a 2WD, it may be easier to look for another one rather than change the tail shaft to fit a transfer case. The E4OD transmission is computer-controlled for the shifts, so if you swap to another model, you'll need to adapt the computer or swap it for one for the donor tranny. It would help if you posted the model for each tranny, and if they are manual or automatic. JSM84
ocalabronco
ocala, Fl
in a word, yes. but you need to clairfy the specifics like JSM said, type of tranny, 4wd/2wd, that kind of stuff. both motors should be small blocks unless you swapped a big block in (doubt it), so they will bolt right up. but the extraneous stuff like computers, clutch pedals, clutch cylinders, intermediate housings, tailshafts, are a different story
89Bronco58
Jersey
u need to first find out if they are both 4wd trannys, then find out if they are the same type of tranny c6, aod ,etc, depending on what tranny it might bolt right up, it nay not, u may need diff electronics, or driveshafts and linkage, find out what kind of trannys they are first
Coastersfwb
