Transmission slips
Dobbs
so I have a 1990 forrd bronco ll. Having problems shifting, and I have no clue what the problem is. I've been told I need a new transmission, but also that it could be a vacum leak, the trans filter, or even shift cylinoids. The shift indicator set up is PRN(D)D21 what kind of transmission is that?!?! I clicked on these links and cannot find it anywhere.
Yo Dobbs,
A4LD is Basically a C3 with OD. Electronically shifted. Strictly light duty ( I.e. A 4 Light Duty) Through 1994 used a combination of hydraulic and electronic shifting. 95 up - electronic shift. Uses vacuum modulator instead of TV linkage. Shift pattern = P-R-N-OD-D-2-1
I have no troubleshooting info on this.
Hopefully others will offer info.
Consider a good repair manual so that you will understand what a shop SHOULD DO..
ATSG Ford A4LD Techtran Transmission Manual Multimedia CD – 2005
by Automatic Transmission Service Group (Author)
5.0 out of 5 stars 2 customer reviews
See all formats and editions
Multimedia CD
from $23.71
3 New from $23.71
https://www.amazon.com/ATSG-Ford-Techtran-Transmission-Manual/dp/B0084G0QDS
Look for better price on the www.
Good luck!!!
Wdtdls
