trans cooler lines
rabbit
My 86 Bronco with 351 C6 auto has the trans cooler lines rusted threw under the radiator does anyone know where to get new ones I shearch the graveyard and found none Thanks
Yo can use hose rated for transmission fluid. I bought steel tubing and made my own.
Give them a call to make sure. They are real helpful. I'd say yes, but there may be a slight difference in length, though my gut feel is yes. Most parts are the same between the two.
http://broncograveyard.com/bronco/i-21180_...ooler_lines.htm
These are the ones for 78/79 with the C6, may ask if they're the same for 80-86. The part number from my NPD catalog is F-7A032-9 or -10, depending on standard or HD cooling option. Also available in stainless.
You can also check with Inline Tubing, since they prolly make the lines for vendors like NPD. But like Seabronco, I made my own hard lines and used rubber hose i nthe same location as the original lines. JSM84
kyleh01
