trans aux cooler
cj_92Bronco
RADFORD VA
hey yall, i bought my rig with a tow package from a family friend and i know he used it for towing and im almost positive it has a tranny aux. cooler but i was wondering if anyone could post a pic of theirs so i could be sure.
thanks alot, CJ
Ok fine, I've mentioned a few times now that it looks just like a small radiator and it will be mounted in the existing engine radiator and plumbed in with hoses that look like fuel lines. If you know it was used for towing and you think you've spotted it than you most likely DO have one and have been looking at it. They're all different depending upon who makes them and I've seen them installed in all sorts of locations, but if you absolutely, positively HAVE to see a photo of one then here these are the best ones I could locate in a quick google search. If you need to see more of them then I'd suggest going to Google.com and searching under "auxillary transmission cooler" and variants of that and I'm sure you'll find all sorts of photos of the coolers themselvs as well as installations.
The look of it depends on who built it and the size used. You will find one line hooked to the transmission and one hooked to the transmission oil cooler built into the radiator.
Here is mine.
eholt80
