towing questions
JesseFixesCATs
i have an 88 ford bronco full size with an automatic transmission i was wondering if i can tow this bronco with all four wheels on the ground with a tow bar. is there anything special i have to do or anything with the steering. if you have any suggestions of a type of tow bar please let me know. ill be hopefully pulling the bronco long distances but no longer than 300 miles at a time
thanks
J
JesseFixesCATs
General rule of thumb is;  The tow veh. should be approx. 20% bigger/stronger than the towed veh.
A trailer is always a better/safer way to go. And the same rule applies.
the tow vehicle would be a 2011 GMC Sierra Z71 with the 5.3 V8. its got the full towing package. i would really like to not have a trailer so i wouldnt have to deal with it when i got to where i was going. in a few years im looking to buy a ford f250 diesel and ill probably get a trailer to tow it then. hopefully a goose neck flat bed trailer. thanks for your reply
I'd remove the drive shafts just to be on the safe side.  It would prevent possible transmission or  transfer case dammage.
Coastersfwb
