Tires
W
Will
Guest
I have a 1988 Ford Bronco II and currently i am lookininto getting new tires.... I want to put the biggest on there wihtout a lift. I am thinking either 235/75/R15 or 235/70/R16... I need some opinions and help deciding
W
Will
Guest
Scratch that.. i have a 15 inch rim.. not the 16! sorry
admin1
Supreme Commander
Administrator
I had a stock 87 Ranger and I was able to get 31" BFG Mud Terrains on it although it was a tight fit and I had to put some coil expanders in the front because it was sagging a little. You may be better off with a 30" tire, other people here in the forum may have a better idea as well what would fit correctly.
Mudslinger
Just put 31s on my 85 BII with 3" body lift. Got enough room in there to swing a cat! So I would imagine 30s would fit OK. :wacko:
walterm
Baton Rouge, La.
>:) just built a 86 B2. I had 235/75R15's but now I have TSL Super Swamper SX 29x10.50R15 its stock hight and theres no rub. If you have stock rims check wheel clearance on the front when turning. aside from that, you won't have any other problems. just be carefull, the axles are not very strong, go too big and your asking for breakage.
monty06
Miami,Florida
i have 33's on one of my b2's with no lift no rub either not stock rims and have 235/75/15 on the other
crashjt
[-X NO WAY!!!!! I HAVE A 1988 B2 WITH A THREE INCH BODY LIFT AND I CAN BARELY SWING 31"S ON A TEN INCH RIM EVEN WITH COIL SPRING SPACERS....I'D SAY ON A STOCK RIM YOU COULD GO NO LARGER THAN A 29 WITH NO RUBBING OR TRIMMING
16417[/snapback]
B.B.BroncoII
Napa, CA
that guy mite have cut off his fenders
fred tyler
