just food for thought but i put 33's on my truck with factory rims and not long afterward three of my wheel studs popped off one of the front tires. i'm thinking it rubbed the radius arm so hard that it put exesive presure on the wheel studs. i'm not sure this is what caused it but just something to think about.
Ahh yes. The wheel stud issue is back.
I will once again post the info and the scans since they seem to have a way of getting lost in the background clutter.
Somewhere along the line (and I only know that it's PRE 87' since the 87' *and* 88" manuals have this BOLD print warning but I don't personally own a set of 86' or earlier manuals (except for the 78/79 manuals I have) to check it against and nobody who DOES own a set has come forward to make any sort of comment)
Somewhere around 86' Ford switched from the old style one-piece acorn type lug nuts to a two-piece captive washer design. The rims were ALSO redesigned when this happened and as you can read from the factory manual using one style of lug nut with the other style rim can & will cause the wheel studs to break. Ford has *specifically* told us this will happen and has strongly advised against using one style with another. Using a set of newer rims with older acorn lugs will snap the studs. Using the old rims with the new lugs will *also* snap the lugs. I cannot imagine in any way that the difference between a 31 (the *factory* tire that a lot of Bronco's were equipped with) and a 33 will rub so hard that the lugs will snap. I've run 33's for 2 or 3 *years* on early 80's Bronco's and never had a problem. Sure, they rub, but not nearly enough to cause a catastrophic failure of the wheel studs. That sort of thing is brought about by something like what Ford describes or some clown cranking them down w/a 500lb impact wrench.
As for the whole lift issue, man are body lifts a pain in the ass. You not only have to change a whole LOT of $hit but as SeaBronc mentioned cooling problems are common because the fan shroud is moved up & above the radiator but even beyond that there are just dozens of small niggling issues to deal with, every linkage & connection requires attention, the brake lines get stretched, the fuel filler neck needs work, the accelerator, brake & clutch linkages have to be modified. The list just goes on & on. The worst part of it is that even after doing all that work you haven't gained a single inch of ground clearance. At least with a suspension lift the problems are more managable and at the end of the day you've not only increased the clearance under the truck but you've increased the suspension travel and that menas the truck can do more & go further than it could before. A body lift does *nothing* to help with the off-road capacity of the rig, it just cranks the body up so someone can stuff large tires underneath and make it LOOK like it's capable of doing something off-road, because after all, appearances are everything and who cares if the thing can ACTUALLY perform off-road, just so long as it LOOKS like it can.
Also, with the larger tires you may want to consider a swap to a saginaw steering box. It'll make steering a LOT easier and it won't give up the ghost nearly as quickly as a stock pump will.
