tilt wheel in 90' bronco?
broncojoe90
I just bought a 90' full size bronco with the 5.0 EFI. I'm curious if i could have it with a tilt steering wheel. I'm tired of driving a bus. And also, the truck runs, but i think it :wacko: could be alot better. Where should i start? Fuel filter? Full tuneup? any one with any info would be greatly appreciated. I'm ready to rip out this 302 and drop in a 351. thanks
Look at your steering column by the turn signal lever look to see if there is a cutout in front of the lever that looks like it would push up into that if it does look like that put a little down pressure on the wheel and push the turn signal lever forward this will release the wheel and you will be able to adjust it :D /emoticons/[email protected] 2x" width="20" height="20" />
BroncoJeff
fLoWmAsTeRs=RuMbLe
Polk City, Florida
First thing i would recomend is seafoam. you can put it straight in to your gas tank and right into your main vacuum line. It will smoke like crazy but its works like you wouldnt believe. i run a 351w in my bronco and its a strong engine. i would definitaly boot the 302 and go 351. as for the steering wheel look for the cut out area or you can always rig your own, that USUALLY works for me. haha good luck
Coastersfwb
